15 years agoFredSAN,
Are you using GoogleSearch or similar software? If you do, try disabling it, or configuring it not to index .zip files, and try again. As for your question, assuming Quartus itself got properly installed, you can install a device family from a QDA file by typing the following from the dos/shell command-line: "quartus_sh --qinstall -qda <location of qda file>" Hope this helps
