10 years agoNMOS switch code
Hi, I'm being a total noob here and a dunce but I'll ask anyway. :) How come the vhdl code attached does not simulate properly. The syntax is correct and it compiles but the signal does not output on...
10 years ago --- Quote Start --- It looks fine to me. Show us how you simulate it and what results you are getting. --- Quote End --- Hi, yeah the problem is that when I simulate using Quartus, even when both the input and gate are high, the output shows 0 transitions. Regardless of how I alter the inputs it always shows no transition. The problem is that it does not simulate properly. Has it simulated properly in your case?
