12 years agoFortunately there are several workflows, I'm glad you found someone that works! I'm sorry we couldn't find the cause of your problem with the Nios flash programmer, I don't really like unsolved mysteries ;) But it's no use spending hours on it if you found another solution that works. Both flows can be entirely automatized with command line scripts, so I don't think there is any advantage or disadvantage of using one over the other.
