12 years agoHi
Commands to generate the hex file are given below. sof2flash --epcs --compress --input=VHDL.sof --output=firmware.flash elf2flash --epcs --after=firmware.flash --input=nios.elf --output=software.flash nios2-elf-objcopy -I srec -O binary firmware.flash firmware.bin nios2-elf-objcopy -I srec -O binary software.flash software.bin cat firmware.bin software.bin > app_image.bin nios2-elf-objcopy -I binary -O ihex app_image.bin app_image.hex UsecQuartus pogrammer to convert this hex file to jic and program the board. Using the above procedure, I am able to program the board and FPGA configures properly.
