13 years agoHi lodentoni,
As Daixiwen told --device=EPCS128 isn't actually relevant. I checked my design and it's the same. So forget about the EPCS128. I am also trying to program my board with FPGA configuartion and NIOS s/w, but not able to succeed. You need to program the FPGA with *.sof, reset the board so that FPGA is configured before you use the Flash programmer from NIOS IDE. If EPCS device is not getting detected even after programming FPGA, then you need to check whether the EPCS flash controller pins are exported to top level or not in FPGA design. I tried flash programming indirecly without using NIOS IDE and itseems to be working at the moment. (use the command line http://www.alteraforum.com/forum/showthread.php?t=31375&p=127299#post127299). Best Regards, Laland PS: Posted this yesterday, but ot ale to ind on thread. So reposting.
