nios2 eclipse 19.4 - Compilation error: nios2-elf-cc: command not found
Hi, Tamir
Can you try below workarounds.
#1
Open a NIOS2 command shell
try and make an NIOS2 application
You get the following error: nios2-elf-gcc.exe: error: CreateProcess: No such file or directory
To resolve this you need run the following command prior to calling make, "export WSLENV=PATH/l:${WSLENV}"
#2
With the above fix you can compile all the files but the link fails:
nios2-elf-g++.exe: error: missing argument to '-msys-lib='
To resolve this you need to modify the application Makefile and change the following line:
APP_LDFLAGS += -msys-lib=$(call adjust-path-mixed,$(SYS_LIB)) to APP_LDFLAGS += -msys-lib=$(SYS_LIB)
In adjust-path-mixed should not be used in this case as SYS_LIB is a name of a library not a PATH to the library
#3
The final problem is that from eclipse debugging fails with the following error:
wslpath: /mnt/f/main_clean/Software/omni_ip/projects/wfm_ss/example/wfm/wfm_app/wfm.elf.srec: No such file or directory
Using cable "USB-BlasterII [USB-1]", device 1, instance 0x01
Pausing target processor: OK
Restarting target processor
rm: cannot remove '/mnt/f/main_clean/Software/omni_ip/projects/wfm_ss/example/wfm/wfm_app/wfm.elf.srec': No such file or directory
To resolve this problem the Application Makefile must be modified again with the following change:
BUILD_PRE_PROCESS := to BUILD_PRE_PROCESS := touch $(ELF).srec
Eric
Step #1 and #2 fixed the compilation error.
I will try step #3 in the next few days and post the answer.
thanks,
tamir
