TSege1
6 years agonios2 eclipse 19.4 - Compilation error: nios2-elf-cc: command not found
Hi All,
I Am using nios2 eclipse 19.4 (Quartos prime pro).
I installd WSL according to nios2 software handbook.
When i trying to compile BSP with small C library option, i get the error:
nio...
EricMunYew_C_Intel
6 years agoHi, Tamir
Would you mind to forward your design to me for replication ?
May I know which Linux you are using ? which wsl you installed etc. ?
Eric
- TSege16 years ago
Hi Eric,
My OS is Windows 10 Pro, OS build 18362.1016
WSL version - Ubuntu 18.04 LTS, WSL 1. installed according to "Nios® II Software Developer
Handbook" version 20.2the "Drag and drop" feature isn't support .sopcinfo file uploading, is there another way i can send you the file?
I think you can reproduce the problem with any .sopcinfo (version19.4) you going to use.
I am trying to Build a simple "Hello World" project.
Tamir
