15 years agoHi Leonardocs,
I think you need to install the Arrow USB-Blaster. I also skipped the first pages and got stuck when I couldn't find the Arrow USB-Blaster. Double click the \BeMicro\programmer\setup.exe. When the "Save As"-Dialog opens, save it in the directory \Altera\ (where your Quartus is installed). Here is another description: --- Quote Start --- 1.5 install the arrow usb-blaster quartus ii programmer plug-in In addition to installing the drivers, you will also need to execute a setup program found in your BeMicro installation directory under “<install directory>\programmer\setup.exe”. You need administrator rights in order to run this setup program. This will install a DLL plug-in to the Quartus Programmer and register the Arrow USB-Blaster as programming hardware available to Quartus. The installation will ask where to store these files. Since the programmer hardware DLL can be used with different release versions of Altera Quartus, you will need to store the DLL in the Altera root program folder, typically C:/altera. This is the location where several folders for different release versions of Altera Quartus might exist. --- Quote End --- It is described in the tutorial: http://www.arrownac.com/offers/altera-corporation/bemicro/bemicro_instructions_embedded_system_lab.pdf Did you mean something else?
