14 years agoI think you are still missing a point: the master address range must be equal or greater than the slave range.
Now you have master : 8bit address , 0x00 to 0x0f slave : 9bit address , 0x00 to 0x1f This way the master can't access the whole slave memory and sopc returns the error. You must increase master range at least one bit. You definitely can do it, since in the original post it was even 0 to 0xffff and I don't know either WHY nor HOW you reduced it. I believe you have some option for this in the component options.
