14 years agoThe error messages are very clear, aren't they? Especially the second one.
Regarding the first one, maybe you are missing one point: you are supposed to always use byte addressing even if you device data is 16- or 32-bit wide. Then, your CDMA_MASTER master port address space range must be at least equal or greater then CDMA_SLAVE slave port range.
