Just for your information this is the kind of assignment I have used in the assignment editor. Obviously you have to find the full path name of the ram block from your compilation output (Compilation report->Fitter->Resource Section->RAM Summary) - may be different if you are using a different version of Quartus - I'm still on 8.1 at the moment.
dsp:dsp0|dsp_processing:dsp_processing_a|buss_mixer:main_group_afl_mix|buss_mix:buss_mix_0|coeff_memory_Xn:coeff_memory_mix_coeffs|coeff_memory_with_byteen:coeff_memory_with_byteen_a|altsyncram:altsyncram_component RAM_BLOCK_TYPE M144K Yes
