15 years agoWell thanks for your reply:
You may get more useful responses if you give more details about your problem. Do you get a specific error message? What exact steps are you taking?""Quote"" I posted a request earlier which so far has given no replies(maybe too informative ?) so I made this tread just to get the ball rolling(sorry for the double post), I still can't post links(until my 5.th post) but you can search for the (maybe not to good to gain interrest) title:error creating session {r,t}xthread terminated w nios ii sbt debugger Could you be so kind as to place a link to this post ? or a link to this in the other post ? "QUOTE=kevin;106679" have successfully used the Nios II SBT for Eclipse debugger under Windows 7 Home Premium x64. Although, I frequently run into an issue(Link removed :-( )which requires me to delete my debug configuration and recreate it on a regular basis. Well I have had only one hardware configuration and it works fine as run configuration, uploading and running software works just fine, so I'm not too much for deleting that. So I tried creating a new debug configuration instead, this didn't change the outcome. --- I keep getting these messeges in my error log: !ENTRY com.altera.sbtgui.launch 1 0 2010-12-05 05:17:05.798 !MESSAGE Done Initializing System Console Model !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.012 !MESSAGE SOPC design not set. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.012 !MESSAGE CPU module not set. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.013 !MESSAGE The SOPC design does not contain a CPU of a support architecture. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.019 !MESSAGE CPU architecture type not set. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.019 !MESSAGE CPU master group not set. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.020 !MESSAGE SOPC design not set. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.021 !MESSAGE CPU module not set. !ENTRY com.altera.sbtgui.launch 4 0 2010-12-05 05:25:18.021 !MESSAGE The SOPC design does not contain a CPU of a support architecture. ---- I don't know if this is related... this is accnowledge as a known bug in eratata and "should be fixed soon".
