12 years agoHi,
If your reset vector address points to the DDR2 Memory you should get this error when you try to run any NIOS project. There's an ALTMEMPHY debug interface, I have used it once to verify a DDR2 design and it was not passing the calibration stage (hardware problem), maybe it's good for you to check it.
