SS5
8 years agoNIOS and WIZNET5300 interfacing Using Tri-state conduit bridge/Generic Tri-state controller
Hello, I want to perform a connection between Nios and Ethernet Module Wiznet W5300. As of now, Using On-chip FIFO Memory core, i am able to read the data in NIOS console. Now, i need to read ...
JOHI
Contributor
8 years agoHello,
I do not understand your statement very good: If you are able to read "the data" in nios, I assume you have a working connection between your fpga board & your wiznet W5300 chip. Then the next step you can do is try to send UDP broadcast messages with your W5300 and use Wireshark (a public domain network sniffer that is one of the best there are) installed on your pc to see if you can send a simple message with the W5300.
If you want to simplify your job: use a second network card in a separate network with only the W5300 and your pc.
Johi.
