NIOS 2 Tool chain
- 5 years ago
I found this instructions now in a ReadMe file and this works out fine.
QUARTUS ECLIPSE MANUAL INSTALLATION
1. Download CDT 8.8.1 which is Eclipse C/C++ IDE for Mars.2
a. Windows: https://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/mars/2/eclipse-cpp-mars-2-win32-x86_64.zip
b. Linux: https://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/mars/2/eclipse-cpp-mars-2-linux-gtk-x86_64.tar.gz
2. Extract the downloaded file into <Quartus installation directory>/nios2eds/bin. You should see <Quartus installation directory>/nios2eds/bin/eclipse
folder after extraction is done.
3. Rename <Quartus installation directory>/nios2eds/bin/eclipse folder to <Quartus installation directory>/nios2eds/bin/eclipse_nios2
4. Extract <Quartus installation directory>/nios2eds/bin/eclipse_nios2_plugins.zip (or tar.gz for Linux) to
<Quartus installation directory>/nios2eds/bin. The extraction will override files in <Quartus installation directory>/nios2eds/bin/eclipse_nios2.
5. Verify the extraction is done correctly by making sure you see <Quartus installation directory>/nios2eds/bin/eclipse_nios2/plugin_customization.ini file
6. You can now launch Nios2 II SBT for Eclipse via eclipse-nios2.exeWith best regards
Gerhard
Hi, Gerhard
Can you follow below to install:
1. install WSL for windows
i. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf (chapter 2.1)
Note: Windows 10 build version 16215.0 or higher is the recommended operating system version.
ii. After installation has successfully completed, launch Ubuntu 18.04.
iii. Install additional distro packages required for Nios II EDS using the following commands:
a. sudo apt-get update
b. sudo apt install wsl
c. sudo apt install dos2unix
d. sudo apt install make
2. install nios2 eclipse folder
3. After re-installation, can you download the patch from below KDB:
