10 years agoNewcomer to VHDL, need help with debugging
Ok so I started learning VHDL about two months ago or so and recently I was handed the following code: https://pastelink.net/1xvg I kinda know what it does as the case statement of "contad...
10 years ago if(rising_edge(clock)) then
if clkdiv="0000000000000" then
clk2 <= '1';
else
clk2<= '0';
end if; </code> Ok, so this part is the one that decides which value of clk2 is sent to the other process. Go it. Thanks. Just one question, how does an input clock's signal work? I suppose it has a frequency in which it changes from 1 to 0 and when it changes to 1 the rising edge returns a true as if it was a boolean, am I right? PD: I have not done a simulation because I am still having problems with the installation of the Xilinx ISE.
