10 years agoNewcomer to VHDL, need help with debugging
Ok so I started learning VHDL about two months ago or so and recently I was handed the following code: https://pastelink.net/1xvg I kinda know what it does as the case statement of "contad...
10 years agoDid you try to run any simulation?
Process which are you asking for, just generates slower clock. clock is an input clock. Signal clkdiv works as a counter here:
clkdiv<=clkdiv+"0000000000001"; With every new clock cycle, clkdiv is increased by 1. For every other value of clkdiv than 0, clk2 is '0'. When clkdiv is bigger than "0000000001000", it is again set to 0 and one cycle later, clk2 is set to '1', but only for one cycle of clock:
if clkdiv="0000000000000" then
clk2 <= '1';
else
clk2<= '0';
end if;
if clkdiv > "0000000001000" then
clkdiv<="0000000000000";
end if;
And then clk2 is used as a clock in other process...
process(clk2)
begin
if(rising_edge(clk2)) then Is the answer ok for you? Regards, kolas
