9 years agoNewbie vs VHDL: season 01 episode 01
Hi all Since I am new to VHDL I have some questions (that probably you will find trivial): 1. Is good practice to define a behavioural architecture with one single process inside or it is ...
9 years agonewbie vs vhdl: season 01 episode 02
Hi all I have a few more question: 1. I read that it is good practice to avoid latches but I cannot understand why they are so bad, in particular I had designed a state machine for a counter: on state A it counts and update a signal, let's call this signal internal_counter, on state B it gives internal_counter as an input to the output value output_counter <= internal_counter. In this way I had latches for all the elements of the std_logic_vector called internal_counter but if I try to reset those value for instance wiriting
when stop =>
output_counter <= internal counter;
internal_counter <= X"000";
next_state <= start;
this proves to be a concurrent statement and so the output is just zeros and so not working. I would like to avoid a third state as long as I do not want to miss any rising edge of the clock controlling the switching between states and I would like to output just a single value at the end of the counting operations. So a concurrent statement out of the process it is likely to avoid any kind of latches and reset issues but give several outputs, not just a single value.
when stop =>
end process;
output_counter <= internal_counter;
2. How do you implement sequential statements working on the same signal and does it make sense? It would mean using an FPGA like a microprocessor...
