Newbie: Logic gates are inverted once deployed to board
- 6 years ago
Many LED driver setups on development boards drive the LED active low, meaning you need to drive the output LOW to turn the LED ON, so a logic 1 is LED OFF, and a logic 0 is LED ON (ie, 'inverted' logic).
This is done because many (older, for the most part) FPGA outputs can sink a lot more current than they can source for driving a LED. Not so true any more with symmetrical high drive CMOS outputs, or usage of LEDs that are very efficient (ie, only require 2ma to light it up).
So the bottom line is you have to look at the schematic of your board to see how the LEDs are driven.
Thanks for your reply. Your post made me look at the issue correctly and realize what was wrong.
Unfortunately, I have not been able to find a schematic of the DE0 board. I suspect Terasic doesn't publish it. They don't show it in the datasheet nor is it available from their website. But they do mention in the manual that high turns on the LED segments. So I was able to verify that after you mentioned they might be on when low. So similar to what you were saying, I had them reversed.
I had them reversed because I originally started out by approaching the display by turning everything segment on, then logically turning off the ones that are not needed. So for say an 8, I turn all of the LEDs on, then turn off segment g. Versus turning on 7 segments, I only turn off the 1. Logically, I think it works out to less gates, less complexity. But in the end, it was confusing and I flipped it to turn on the ones I need, but left the inverted logic setup.
Of course, hardcoding this in 12 lines of Verilog or VHDL is the way to go. I was just working through this as a learning exercise. Thanks for your help.
Jon Rothlander
