Newbie: Logic gates are inverted once deployed to board
- 6 years ago
Many LED driver setups on development boards drive the LED active low, meaning you need to drive the output LOW to turn the LED ON, so a logic 1 is LED OFF, and a logic 0 is LED ON (ie, 'inverted' logic).
This is done because many (older, for the most part) FPGA outputs can sink a lot more current than they can source for driving a LED. Not so true any more with symmetrical high drive CMOS outputs, or usage of LEDs that are very efficient (ie, only require 2ma to light it up).
So the bottom line is you have to look at the schematic of your board to see how the LEDs are driven.
Hi Jon,
Have you simulate your and gate? Is it behave as expected? Where both input "HIGH" output is "HIGH"?
- jrothlander6 years ago
Good point. I have not figure out how to run a simulation yet. I did try to run the simulation, but it fails to start. So I'll focus on getting that worked out.
Thanks for the suggestion.
