JWrig25
6 years agoNew error when programming device: "Unable to scan device chain. On-board programming hardware is disabled."
I have been trying to get the Avalon-MM design programmed on my Stratix V GX FPGA Development Kit. I finally got it to compile on an old version of Quartus since the newer versions are not compatible...
JohnT_Altera
6 years agoHi,
If you look into SW4 shown in Figure 4 inhttps://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf then you can check what is the setting is set to.
- JWrig256 years ago
SW4 is in the factory default setup, so all the switches are in the On(0) position except for MSEL3 which is in the OFF(1) position. What should I change it to?
