JWrig25
6 years agoNew error when programming device: "Unable to scan device chain. On-board programming hardware is disabled."
I have been trying to get the Avalon-MM design programmed on my Stratix V GX FPGA Development Kit. I finally got it to compile on an old version of Quartus since the newer versions are not compatible...
JohnT_Altera
6 years agoHi,
May i know what configuration mode are you using on your board? If you are using AS mode then can you change the MSEL to other setting and try to reprogram the FPGA?
JWrig25
6 years agoI am not sure what config mode is being used, I know that when the board turns on, it will load the current image and light up the config done LED. How do I find the config mode I am using?
