JWrig25
6 years agoNew error when programming device: "Unable to scan device chain. On-board programming hardware is disabled."
I have been trying to get the Avalon-MM design programmed on my Stratix V GX FPGA Development Kit. I finally got it to compile on an old version of Quartus since the newer versions are not compatible...
JohnT_Altera
6 years agoHi,
May I know if you have other boards to test out? Are you able to see that the board is power up successfully?
JWrig25
6 years agoHi,
I do have one other Stratix V GX FPGA Development Kit, that was the original device I was using until the board got corrupted via programming by Quartus Prime, and that one also since then became unprogrammable. That is when I moved to my current second board which now also doesn't work. I do believe the boards power up correctly with the Config Done LED lighting up, but they power up into a different "programmed state" than the original factory default state.
