Nested SystemVerilog/Verilog Include Files
- 5 years ago
I think the problem is the fact that you declared a typedef in a header file. Because they're usually declared in a verilog HDL file before the module declaration, but I don't think that's what you want to do.
Header files are problematic in general, which is why SystemVerilog introduced us to packages: https://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=6469140
You should use packages instead of `include. You can populate packages with parameters too.
Nurina
Unfortunately the KDB did not help me. I changed the build script to include
set_global_assignment -name VERILOG_INPUT_VERSION SYSTEMVERILOG_2012
but that didn't remove the error.
I have attached the project as it stands if it would be possible for you to have a look? It has not really changed from the first post, apart from having the SystemVerilog flag. It is run in the same way.
David
Maybe it could be something to do with this warning?
Warning(16847): Verilog HDL warning at parameters.vh(8): concatenation member label not yet supported; label ignored
