9 years agonested loop error in OpenCL hardware run
Hello, My openCL project produced wrong output in hardware run, and after several days debug, I finally found out the reason. The index in one of my nested loop structure is messed up and I rea...
9 years agoAssuming this is a single work-item kernel, oop pipelining, performed by aoc, will launch the next iteration of the outer loop, and subsequently the inner loop as soon as it can if there are no dependencies. That seems to be the case here.
