15 years agoHi Cris
Back on this problem again. I'm actually using this options you've mentioned. I still have some negative slacks there. One example is the following: Slack: -1.767 From node: RST_N (it's actually an input pin from my system) To node: rst_debounce:inst4|input_sync (it's actually the first register on synchonizer chain for this specific input) Launch clock: CLK (it's the only global clock, PLL input for my system) Latch clock: altpll1:inst7|altpll:altpll_component|altpll_34o2:auto_generated|clk[0] (it's one of my pll outputs, generated by "derive_pll_clocks" Relationship: 0.100 Clock skew: 0.018 Data delay: 1.264 Not sure how should I handle this...
