13 years agoNeed help with VHDL error here
Error (10476): VHDL error at scomp.vhd(64): type of identifier "AC_SHIFTED" does not agree with its usage as "std_logic_vector" type
Error (10558): VHDL error at scomp.vhd(64): cannot associate formal port "RESULT" of mode "out" with an expression LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; LIBRARY ALTERA_MF; USE ALTERA_MF.ALTERA_MF_COMPONENTS.ALL; LIBRARY LPM; USE LPM.LPM_COMPONENTS.ALL; ENTITY SCOMP IS PORT( CLOCK : IN STD_LOGIC; RESETN : IN STD_LOGIC; PC_OUT : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0); AC_OUT : OUT STD_LOGIC_VECTOR(15 DOWNTO 0); MDR_OUT : OUT STD_LOGIC_VECTOR(15 DOWNTO 0); MAR_OUT : OUT STD_LOGIC_VECTOR( 9 DOWNTO 0); IO_WRITE : OUT STD_LOGIC; IO_CYCLE : OUT STD_LOGIC; IO_ADDR : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0); IO_DATA : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0) ); END SCOMP; ARCHITECTURE a OF SCOMP IS TYPE STATE_TYPE IS ( RESET_PC, FETCH, DECODE, EX_LOAD, EX_STORE, EX_STORE2, EX_ADD, EX_SUB, EX_JNEG, EX_JPOS, EX_JZERO, EX_JUMP, EX_AND, EX_OR, EX_XOR, EX_ADDI, EX_SHIFT, AC_SHIFTED ); SIGNAL STATE : STATE_TYPE; SIGNAL AC : STD_LOGIC_VECTOR(15 DOWNTO 0); SIGNAL IR : STD_LOGIC_VECTOR(15 DOWNTO 0); SIGNAL MDR : STD_LOGIC_VECTOR(15 DOWNTO 0); SIGNAL PC : STD_LOGIC_VECTOR(9 DOWNTO 0); SIGNAL MEM_ADDR : STD_LOGIC_VECTOR(9 DOWNTO 0); SIGNAL MW : STD_LOGIC; BEGIN SHIFTER: LPM_CLSHIFT -- Use LPM_CLSHIFT to shift AC GENERIC MAP( lpm_width => 16, lpm_widthdist => 4, lpm_shifttype => "LOGICAL" ) PORT MAP( data => AC, distance => IR(3 downto 0), direction => IR(4), result => AC_SHIFTED <----1st and 2nd error here ); MEMORY : altsyncram -- Use altsyncram component for unified program and data memory GENERIC MAP ( intended_device_family => "Cyclone", width_a => 16, widthad_a => 10, numwords_a => 1024, operation_mode => "SINGLE_PORT", outdata_reg_a => "UNREGISTERED", indata_aclr_a => "NONE", wrcontrol_aclr_a => "NONE", address_aclr_a => "NONE", outdata_aclr_a => "NONE", init_file => "TEST_CODE.mif", lpm_hint => "ENABLE_RUNTIME_MOD=NO", lpm_type => "altsyncram" ) PORT MAP( wren_a => MW, clock0 => NOT(CLOCK), address_a => MEM_ADDR, data_a => AC, q_a => MDR ); PC_OUT <= PC; AC_OUT <= AC; MDR_OUT <= MDR; MAR_OUT <= MEM_ADDR; IO_WRITE <= '0'; IO_CYCLE <= '0'; IO_ADDR <= IR(7 DOWNTO 0); WITH STATE SELECT MEM_ADDR <= PC WHEN FETCH, IR(9 DOWNTO 0) WHEN OTHERS; PROCESS (CLOCK, RESETN) BEGIN IF (RESETN = '0') THEN -- Active low, asynchronous reset STATE <= RESET_PC; ELSIF (RISING_EDGE(CLOCK)) THEN CASE STATE IS WHEN RESET_PC => MW <= '0'; -- Clear memory write flag PC <= "0000000000"; -- Reset PC to the beginning of memory, address 0x000 AC <= x"0000"; -- Clear AC register STATE <= FETCH; WHEN FETCH => MW <= '0'; -- Clear memory write flag IR <= MDR; -- Latch instruction into the IR PC <= PC + 1; -- Increment PC to next instruction address STATE <= DECODE; WHEN DECODE => CASE IR(15 downto 10) IS WHEN "000000" => -- No Operation (NOP) STATE <= FETCH; WHEN "000001" => -- LOAD STATE <= EX_LOAD; WHEN "000010" => -- STORE STATE <= EX_STORE; WHEN "000011" => -- ADD STATE <= EX_ADD; WHEN "000100" => -- SUB STATE <= EX_SUB; WHEN "000101" => -- JUMP STATE <= EX_JUMP; WHEN "000110" => -- JNEG STATE <= EX_JNEG; WHEN "000111" => -- JPOS STATE <= EX_JPOS; WHEN "001000" => -- JZERO STATE <= EX_JZERO; WHEN "001001" => -- AND STATE <= EX_AND; WHEN "001010" => -- OR STATE <= EX_OR; WHEN "001011" => -- XOR STATE <= EX_XOR; WHEN "001101" => -- ADDI STATE <= EX_ADDI; WHEN "001100" => -- SHIFT STATE <= EX_SHIFT; WHEN OTHERS => STATE <= FETCH; -- Invalid opcodes default to NOP END CASE; WHEN EX_LOAD => AC <= MDR; -- Latch data from MDR (memory contents) to AC STATE <= FETCH; WHEN EX_STORE => MW <= '1'; -- Raise MW to write AC to MEM STATE <= EX_STORE2; WHEN EX_STORE2 => MW <= '0'; -- Drop MW to end write cycle STATE <= FETCH; WHEN EX_ADD => AC <= AC + MDR; STATE <= FETCH; WHEN EX_SUB => AC <= AC - MDR; STATE <= FETCH; WHEN EX_JUMP => PC <= IR(9 DOWNTO 0); STATE <= FETCH; WHEN EX_JNEG => IF AC(15) = '1' THEN PC <= IR(9 downto 0); END IF; STATE <= FETCH; WHEN EX_JPOS => IF AC(15) = '0' AND AC /= x"0000" THEN PC <= IR(9 downto 0); END IF; STATE <= FETCH; WHEN EX_JZERO => IF AC = x"0000" THEN PC <= IR(9 downto 0); END IF; STATE <= FETCH; WHEN EX_AND => AC <= AC AND MDR; STATE <= FETCH; WHEN EX_OR => AC <= AC OR MDR; STATE <= FETCH; WHEN EX_XOR => AC <= AC XOR MDR; STATE <= FETCH; WHEN EX_ADDI => IF IR(9)='0' THEN AC <= AC + ("000000"&IR(9 downto 0)); ELSE AC <= AC + ("111111"&IR(9 downto 0)); END IF; STATE <= FETCH; WHEN EX_SHIFT => AC <= AC_SHIFTED; STATE <= Fetch; WHEN OTHERS => STATE <= FETCH; -- If an invalid state is reached, return to FETCH END CASE; END IF; END PROCESS; END a;5 Replies
AC_SHIFTED is part of the state_type, and so has no specific value - the compiler will chose the value for you. If you want specific std_logic_vector values, you will need to specify them yourself.
You also get the error because you're trying to assign a value to an out port (you can only connect an output to a signal, not a constant or an input). - Altera_Forum
TO_BE_DONE
main code has lots of components as below , above errors are associated with component calls in the main alu code.
--LIBRARY USAGE library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_signed.all; use ieee.numeric_std.all; --ENTITY OF 64 BIT ARITHMETIC LOGIC UNIT entity alu_64 is generic(K :natural:=64) ; port (input1 :in std_logic_vector(K-1 downto 0) ; input2 :in std_logic_vector(K-1 downto 0) ; alu_cont:in std_logic_vector(4 downto 0) ; clk :in std_logic ; reset :in std_logic ; alu_out :out std_logic_vector(K-1 downto 0) ; alu_rout:out std_logic_vector(K-1 downto 0) ; flag_reg:out std_logic_vector(4 downto 0)) ; end alu_64; --BEHAVIORAL DESIGN ARCHITECTURE OF 64 BIT ARITHMETIC LOGIC UNIT architecture behavioral of alu_64 is -----------------------------DECLERARION OF MUTIAL REQUIREMENTS--------------------------------- --Mutual signal declerations shared variable temp_alu_out :std_logic_vector(K-1 downto 0) ; shared variable temp_alu_rout:std_logic_vector(K downto 0) ; shared variable temp_flag_reg:std_logic_vector(4 downto 0) ; shared variable CF :std_logic ; shared variable OVF :std_logic ; shared variable ZF :std_logic ; shared variable PF :std_logic ; shared variable SF :std_logic ; --Mutual function decleration --Carry Flag function decleration function C_F(input : std_logic) return std_logic is begin if input = '1' then return '1'; end if; return '0'; end C_F; --Overflow Flag function decleration function OV_F(input : std_logic) return std_logic is begin if input = '1' then return '1'; end if; return '0'; end OV_F; --Zero Flag function decleration function Z_F(input : std_logic_vector) return std_logic is begin if input = x"00000000" then return '1'; end if; return '0'; end Z_F; --Parity Flag function decleration function P_F(input : std_logic_vector) return std_logic is variable counter:integer:= 0; begin for i in 0 to K-1 loop if(input(i) = '1') then counter := counter + 1; end if; end loop; if(counter mod 2 = 0) then return '1'; end if; return '0'; end P_F; --Sign Flag function decleration function S_F(input : std_logic) return std_logic is begin if(input = '1') then return '1'; end if; return '0'; end S_F; --------------------------------ARITHMETIC UNIT DECLERARIONS----------------------------------- --SIGNAL DECLERATIONS --Signal declerations for ADD_64 (64 bit unsigned adder) shared variable temp_add_out :std_logic_vector(K-1 downto 0); shared variable temp_cout :std_logic; --signal declerations for SADD_64 (64 bit signed adder) shared variable temp_sadd_out :std_logic_vector(K-1 downto 0); shared variable temp_scout :std_logic; --signal declerations for SUB_64 (64 bit unsigned subtracter) shared variable temp_sub_out :std_logic_vector(K-1 downto 0); shared variable temp_borrowout :std_logic; --signal declerations for SSUB_64 (64 bit signed subtracter) shared variable temp_ssub_out :std_logic_vector(K-1 downto 0); shared variable temp_sborrowout:std_logic; --signal declerations for MULT_64(64 bit signed and unsigned multiplier) shared variable temp_mult_out :std_logic_vector(2*K-65 downto 0); --signal declerations for DIV_64 (64 bit signed and unsigned divisor) shared variable temp_quotient :std_logic_vector(K-1 downto 0); shared variable temp_remainder :std_logic_vector(K downto 0); --signal declerations for MOD_64 (64 bit signed and unsigned modulator) shared variable temp_mod_out :std_logic_vector(K downto 0); - Altera_Forum
TO_BE_DONE
Port maps cannot be connected to shared variables - they can only connect to signals.
