13 years agoNeed help with VHDL error here
Error (10476): VHDL error at scomp.vhd(64): type of identifier "AC_SHIFTED" does not agree with its usage as "std_logic_vector" type Error (10558): VHDL error at scomp.vhd(64): cannot associate fo...
8 years agomain code has lots of components as below , above errors are associated with component calls in the main alu code.
--LIBRARY USAGE library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_signed.all; use ieee.numeric_std.all; --ENTITY OF 64 BIT ARITHMETIC LOGIC UNIT entity alu_64 is generic(K :natural:=64) ; port (input1 :in std_logic_vector(K-1 downto 0) ; input2 :in std_logic_vector(K-1 downto 0) ; alu_cont:in std_logic_vector(4 downto 0) ; clk :in std_logic ; reset :in std_logic ; alu_out :out std_logic_vector(K-1 downto 0) ; alu_rout:out std_logic_vector(K-1 downto 0) ; flag_reg:out std_logic_vector(4 downto 0)) ; end alu_64; --BEHAVIORAL DESIGN ARCHITECTURE OF 64 BIT ARITHMETIC LOGIC UNIT architecture behavioral of alu_64 is -----------------------------DECLERARION OF MUTIAL REQUIREMENTS--------------------------------- --Mutual signal declerations shared variable temp_alu_out :std_logic_vector(K-1 downto 0) ; shared variable temp_alu_rout:std_logic_vector(K downto 0) ; shared variable temp_flag_reg:std_logic_vector(4 downto 0) ; shared variable CF :std_logic ; shared variable OVF :std_logic ; shared variable ZF :std_logic ; shared variable PF :std_logic ; shared variable SF :std_logic ; --Mutual function decleration --Carry Flag function decleration function C_F(input : std_logic) return std_logic is begin if input = '1' then return '1'; end if; return '0'; end C_F; --Overflow Flag function decleration function OV_F(input : std_logic) return std_logic is begin if input = '1' then return '1'; end if; return '0'; end OV_F; --Zero Flag function decleration function Z_F(input : std_logic_vector) return std_logic is begin if input = x"00000000" then return '1'; end if; return '0'; end Z_F; --Parity Flag function decleration function P_F(input : std_logic_vector) return std_logic is variable counter:integer:= 0; begin for i in 0 to K-1 loop if(input(i) = '1') then counter := counter + 1; end if; end loop; if(counter mod 2 = 0) then return '1'; end if; return '0'; end P_F; --Sign Flag function decleration function S_F(input : std_logic) return std_logic is begin if(input = '1') then return '1'; end if; return '0'; end S_F; --------------------------------ARITHMETIC UNIT DECLERARIONS----------------------------------- --SIGNAL DECLERATIONS --Signal declerations for ADD_64 (64 bit unsigned adder) shared variable temp_add_out :std_logic_vector(K-1 downto 0); shared variable temp_cout :std_logic; --signal declerations for SADD_64 (64 bit signed adder) shared variable temp_sadd_out :std_logic_vector(K-1 downto 0); shared variable temp_scout :std_logic; --signal declerations for SUB_64 (64 bit unsigned subtracter) shared variable temp_sub_out :std_logic_vector(K-1 downto 0); shared variable temp_borrowout :std_logic; --signal declerations for SSUB_64 (64 bit signed subtracter) shared variable temp_ssub_out :std_logic_vector(K-1 downto 0); shared variable temp_sborrowout:std_logic; --signal declerations for MULT_64(64 bit signed and unsigned multiplier) shared variable temp_mult_out :std_logic_vector(2*K-65 downto 0); --signal declerations for DIV_64 (64 bit signed and unsigned divisor) shared variable temp_quotient :std_logic_vector(K-1 downto 0); shared variable temp_remainder :std_logic_vector(K downto 0); --signal declerations for MOD_64 (64 bit signed and unsigned modulator) shared variable temp_mod_out :std_logic_vector(K downto 0);
