12 years ago
Need help with my .vwf file to simulate my vhdl design file
I'm having an awful time getting my vwf file to simulate correctly. I just keep running into errors. Can someone help me out or point me in the right direction on how to set this up. I understand there are many ways to simulate this but all I want is to add and subtract numbers. I would like to increment AI by 1 and BI by two so their not the same. I'm wanting the simulation to switch operations "addition and subtraction" when my selector "SE" is 1 or 0 like i instructed in my code.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity add_sub_2 is
port (
AI,BI : in integer range 0 to 15;
SE : in std_logic_vector (2 downto 0);
SO : out integer range 0 to 32);
end add_sub_2 ;
architecture add_sub of add_sub_2 is
BEGIN
WITH SE SELECT
SO <= AI + BI WHEN "000",
AI - BI WHEN "001",
AI + BI WHEN others;
end add_sub ;
1 Reply
    You would be better off learning to write testbenches rather than using vwf files.
