10 years agoNeed help with my final project design (Ethernet Transmitter)
Hi all, My goal is to build Ethernet Transmitter based pipeline. I already built few things and I have few questions: 1. I want to take my input (ethernet 2 / 802.3 frames) from a TEX...
10 years ago1. I assume you mean for simulation? File IO is not synthesisable. Either way, you should know the size of your vector in runtime. When you issue a read command it will try and fit the text to the vector.
Why not post some example code so we can try and understand what you're trying to do...
