13 years ago --- Quote Start --- i checked the path... is rebuild is to compile the project ? if it is , i allready did so... --- Quote End --- either: you are using the wrong sof (if it is signaltap observation) or your signaltap observation is wrong or you are building with past mif file or you are not rebuilding or you are not updating the right file (also note it could be using hex, check extension) or you are very unlucky Remember the tool hasn't got memory of the past...
