13 years agoCheck the path of the .mif file, then save and update the rom instantiation, then compile the whole logic project(attention to top module file set).
If you copy a project bak, that the .sof file download may be at the old path, please check the creation time of the .sof file before download (check the compile time and the .sof file time info to find the lateast one, also check the time of the mif file after update it), just to do that...
