17 years agoHi,
I mean apply Z in a combinatorial assignment, not on the clk edge due to clk latency issues. Imagine at a clk edge your wr = '1' so your module reads in data_io: --- Quote Start --- if (we='1') then my_ram256x8(conv_integer(address))<=data_io; end if; --- Quote End --- At the same clk edge when wr = '1' you apply Z on data_io, fair enough but this means data_io will become Z(will be cutoff) just after this edge. so when you take data_io to your ram it is still not cutoff from your own drive. --- Quote Start --- if rising_edge (clk) then if (oe = '1' and we = '0') then data_io <= data_out; else data_io <= "ZZZZZZZZ"; end if; end if; end process; --- Quote End --- Here is my version(off my head so check for mistakes): entity ram1 is port( clk : in std_logic; we : in std_logic; oe : in std_logic; address: in std_logic_vector(7 downto 0); data_io : inout std_logic_vector(7 downto 0) ); end ram1; architecture rtl of ram1 is signal data_out : std_logic_vector(7 downto 0); type ram_type is array (255 downto 0) of std_logic_vector(7 downto 0); signal my_ram256x8 : ram_type := (others => (others => '0')); begin data_io <= data_out when (oe = '1' and we = '0') else (others => 'Z'); process(clk) begin if rising_edge(clk) then if oe = '1' then if we = '1' then my_ram(conv_integer(address)) <= data_io; -- write else data_out <= my_ram(conv_integer(address)); -- read end if; end if; end if; end process; end rtl;
