17 years agoThanks for pointing out the mistake. It was a mistake there. Sorry! Using automatic generation of code would not do any good for learning process.
____________________________________________________________________________Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ram1 is
PORT(address: in std_logic_vector(7 downto 0);
clk: in std_logic;
we: in std_logic;
oe: in std_logic;
data_io: inout std_logic_vector(7 downto 0));
end ram1;
ARCHITECTURE rtl OF ram1 IS
signal data_out : std_logic_vector(7 downto 0);
TYPE ram_type IS ARRAY(255 downto 0) OF std_logic_vector(7 DOWNTO 0);
SIGNAL my_ram256x8 : ram_type:=(others=>(others=>'0'));
BEGIN
process (clk)
begin
if rising_edge (clk) then
if (oe = '1' and we = '0') then
data_io <= data_out;
else
data_io <= "ZZZZZZZZ";
end if;
end if;
end process;
process(clk)
begin
if (clk'event and clk='1') then
if (we='1') then
my_ram256x8(conv_integer(address))<=data_io;
end if;
end if;
end process;
process(clk)
begin
if (we='0' and oe='1') then
data_out<=my_ram256x8(conv_integer(address));
end if;
end if;
end process;
END rtl;
