8 years agoNDRnage Kernels Global Memory Write Pattern
I came up with some basic questions, which I would like to discuss: 1) I still don't understand how SIMD is being implemented in FPGA. In GPU, workitems being assigned to SIMDs are being execut...
8 years agoYou should post your kernel code; what you are observing is very likely because you have something in your code that is preventing vectorization (e.g. work-item ID-dependent branching) and hence, SIMD is not being applied at all. If this is indeed the case, you will see a message form the compiler about this in the log.
