8 years agoNDrange, work-itme level parallelism vs work-group level parallelism
Hello, I have an ambiguity regarding ND-range. Suppose we have a ND range with 1 Device, 4 CUs (compute units), and 1 PE inside each CU (1 PE means no SIMD). I already know that loop pipelining ...
8 years agoMaybe I simplified things a little bit too much. It is not just about divisibility. As you said, there is no guarantee that work-groups running in different CUs would finish at the same time, hence some CUs will always remain unused. However, with more work-groups, the chance of a CU being unused will get smaller, resulting in closer-to-linear speed-up with number of CUs. Furthermore, at least based on what Altera's report claims, there is also work-group pipelining in place and hence, there could be multiple work-groups in-flight in the same CU at the same time and having more work-groups will further help to keep the CU busy.
