10 years agoNDRange Channel Implementation
I'm having some problems with the execution of two kernels communicating via channels in the NDRange environment. Basically there are two kernels with different numbers of work-items and different w...
10 years agomay be you could use to print all the item id and all the data that have been writen and read from the channel to see what happened
