10 years agoNativeLink simulation flow was NOT successful
Hello, I am trying to integrate Altera Triple-Speed Ethernet IP into my design but I cannot simulate it. When I remove this IP, I can simulate successfully using ModelSim. The Quartus version that...
10 years agoHello,
Here are some more information: I've just found that I can no longer run any simulations (starting from Quartus) even if I remove all the Altera Triple-Speed Ethernet references. Something got changed somewhere and I do not know what to do. So, I have created a new project and add all the RTL code that I had, at the exception of the Altera Triple-Speed Ethernet module. Everything is working fine and I can start a simulation from Quartus. Then, I created a new instance for the Altera Triple-Speed Ethernet. This means that the new instance is now part of the Quartus project. I did not add the instantiation inside my RTL yet and this was good enough to trigger the same errors as described above. This means that the issue is caused by the creation of the IP itself. Does this give any clue to someone?
