11 years agoNativelink Error "can not find channel named ... no such file or directory"
Hello, I am new to Altera products and VHDL and I have problem when I go to Tools > Run Simulation Tools > RTL Simulation. When I do this, after compiling with success a small sample of VHDL code, I ...
11 years agoHello,
Sorry for the late reply. I was (in fact, I am) too busy these days and Gmail marked the altera forum notification as spam. kennyboy2020, the latest edition did not work in my system. ah_zhi02, I just read the .rpt but did not have too much additional information that I could understand. Here is the report:
Info: Start Nativelink Simulation process
Error : Can't open file -- /home/nicholasyukio/Documents/5º semestre/EEA-21/VHDL/projeto/main.vhd
can not find channel named "couldn't open "/home/nicholasyukio/Documents/5º semestre/EEA-21/VHDL/projeto/main.vhd": no such file or directory"
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: TCL LOOKUP CHANNEL {couldn't open "/home/nicholasyukio/Documents/5º semestre/EEA-21/VHDL/projeto/main.vhd": no such file or directory}
Nativelink TCL script failed with errorInfo: can not find channel named "couldn't open "/home/nicholasyukio/Documents/5º semestre/EEA-21/VHDL/projeto/main.vhd": no such file or directory"
while executing
"eof $file_id "
(procedure "get_ip_info" line 20)
invoked from within
"get_ip_info $full_file_name"
(procedure "run_eda_simulation_tool" line 195)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
I did installed Modelsim but here in Linux enviroment but it did not created shortcuts in desktop nor in menus, so I thought its initialization was by Quartus. bfkstimchan: I tried to start Modelsim indenpedently (as stated above) but I did not have sucess. Any way, I gave up (at least for a while) in using Altera products in Linux Mint and installed in Windows 7 and I did not found the same problems. If anybody here currently uses Altera products in Linux (especially Mint) I would be happy to know how he/she succeed in the task (for instance, how to start Modelsim independently outside Quartus without shortcuts). I thank the help received.
