11 years agoNativelink Error "can not find channel named ... no such file or directory"
Hello, I am new to Altera products and VHDL and I have problem when I go to Tools > Run Simulation Tools > RTL Simulation. When I do this, after compiling with success a small sample of VHDL code, I ...
11 years agoHi,
You can invoke Modelsim independently without the need to open it through Quartus II. You may try to see if it can launch Modelsim this way? This could serve as workaround for the existing issue.
