11 years agoNativelink Error "can not find channel named ... no such file or directory"
Hello, I am new to Altera products and VHDL and I have problem when I go to Tools > Run Simulation Tools > RTL Simulation. When I do this, after compiling with success a small sample of VHDL code, I ...
11 years agoHi,
Seems like a missing link issue... Did you try open the report (*.rpt) and check what is the error? Also did you have the modelsim installed? Then make sure you also setup the modelsim directory in the tools.
