10 years agoNaming Values in ModelSim Wave with an Alias
Hi all, I am wondering if there is a way to define a set of aliases for a models signal. Basically, I want to do the following: 1) I have a 5bit signal in the ModelSim waveform window call...
10 years agoThis is what I was looking for!
With some more research after this, I found another good example on p67 of the following document: http://wiki.eng.iastate.edu/cpre584/images/3/3c/modelsim_pe_user_10.0d.pdf Thanks Tricky!
