11 years agonallatech SDK problem
hi There are some SDK (pcie385n_a7 and pcie385_d5). But when I execute the helloworld program , I can not execute successfully. I tried to execute other program , the same situation happen...
11 years agoWhen running the flash_recovery script, the board must be powered and connected to the JTAG programming cable as shown in the doc linked below. You must run the script from the computer the JTAG programming cable is plugged into with the USB cable. The board must be powered.
Also, please make sure the USB config file is correctly setup: https://www.altera.com/support/support-resources/download/drivers/dri-usb_b-lnx.html You might also need to run as root. http://www.alteraforum.com/forum/attachment.php?attachmentid=8908&d=1400634781
