11 years agonallatech SDK problem
hi There are some SDK (pcie385n_a7 and pcie385_d5). But when I execute the helloworld program , I can not execute successfully. I tried to execute other program , the same situation happen...
11 years agohi
I have done the step ( Connect the USB cable to the host) lspci (Unassigned class [ff00]: Altera Corporation Device ab00) But I entered the directory : /home/user/altera/14.0/hld/boards/nalla_pcie/hardware/p385_hpc_d5 and ran the perl flash_recovery.pl base.aocx The error messages showed that """""""""""""""" Error (209062): Flash Loader IP not loaded on device 0 Error (209053): Unexpected error in JTAG server -- error code 5 Error (209053): Unexpected error in JTAG server -- error code 89 Error (209012): Operation failed Info (209061): Ended Programmer operation at Fri Jul 24 09:38:18 2015 Error: Quartus II 64-Bit Programmer was unsuccessful. 4 errors, 0 warnings Error: Peak virtual memory: 1681 megabytes Error: Processing ended: Fri Jul 24 09:38:18 2015 Error: Elapsed time: 00:00:05 Error: Total CPU time (on all processors): 00:00:05 Error: quartus_cpf failed at flash_recovery.pl line 92. """""""""""""""" How to solve the problem ?
