11 years agoHi The Smith,
what do you mean plug the board back in? The 385 must be in the host, powered up. The USB-Blaster cable must be connected to the 385. The USB-Blaster must be connected to the computer you are running the "aocl flash ..." command from. See 385/USB-Blaster connections here: http://www.alteraforum.com/forum/attachment.php?attachmentid=8908&d=1400634781 For RedHat users, please see: http://www.altera.com/download/drivers/dri-usb_b-lnx.html Some of the commands/services used within the flash update process must be run as 'root'. Thanks, G
