999timur999
5 years agomy scheme simulation is ok , but test have errors
# ** Error: (vlog-13069) Waveform.vwf.vt(40): near "1": syntax error, unexpected INTEGER NUMBER, expecting IDENTIFIER or TYPE_IDENTIFIER or NETTYPE_IDENTIFIER.
# ** Error: (vlog-13069) Waveform.vwf...
Nurina
5 years agoHi,
These errors mean there are errors in your verilog/VHDL code.
From the bdf I can see that your output signal names start with a number. This isn't allowed in verilog/VHDL and you need to rename them starting with an alphabet.
Error: (vlog-13069) Waveform.vwf.vt(50): near "Q0": syntax errir, unexpected IDENTIFIER, expecting ')'.
I can't tell why you get this error from your bdf. Can you attach the "Waveform.vwf.vt" file?
Nurina
