8 years agoMux for INOUT ports
NT - please delete
And what problems are you having?
--- Quote Start --- And what problems are you having? --- Quote End --- Sorry, I forgot to write... Both ports appear to not send or receive any data if I use the mux. - Altera_Forum
have you simulated the design? does it work? have you tried signaltap to investigate the situation and see if all control is as you expected?
--- Quote Start --- have you simulated the design? does it work? have you tried signaltap to investigate the situation and see if all control is as you expected? --- Quote End --- Yes, seems to be working on the simulation, but I didn't try the signaltap. I used only a few times some years ago, so I need to re-learn about it.
