10 years agoMultiple state machines in one module
How do I create multiple state machines in the same module (but different always blocks), and have them recognized as state machines by Quartus II? I used the method recommended in an Altera handbook...
10 years ago --- Quote Start --- Just add more than one state machine. Quartus seems to recognise any case statement which changes a register between different entries as a state machine. I call all my state machines things like "stateMachine", "mgmtStateMachine", etc. It helps to use (in Verilog at least) localparam definitions for each of your states. --- Quote End --- I found that unless each state machine follows very specific rules, they won't show up. It is also possible that you're missing something, for example using a blocking assignment instead of a non-blocking in a single state, that is causing issues. Getting the syntax correct can cause a headache for the viewer. I'd double-check that first. I have several modules with 3+ state machines, so it has to be something else. I write mine differently (all synchronous), but it works either way.
