HPA
4 years agoMultiple SRAM versions in a project
I have a project for which I would like to generate multiple versions of the same design differing *only* in the firmware loaded into SRAM. I obviously don't want to have to do a full recompile for e...
HPA
4 years agoThere have been some suggestions on the net to generate the RAM blocks in HDL and then replace the .mif files directly in the database directory. This, presumably, would work, although is perhaps more than a bit cantankerous?
