multiple drivers due to the non-tri-state driver
I tried to compile the design in the Pro edition and the errors below occurred. These errors are not captured in the Standard edition where I believe this is due to the limited SystemVerilog language support in the Standard edition software. I will file a case to engineering team and report the inconsistent behavior between the two editions. Please upgrade the software to Pro edition as Standard edition has limited language support.
Error(13386): Verilog HDL Procedural Assignment error at SDRAMController8Bit.sv(1304): object "sd_D" on left-hand side of assignment must have a variable data type
Error(13363): Verilog HDL error at SDRAMController8Bit.sv(1574): module "SDRAMController8Bit" ignored due to previous errors
Error(17232): Verilog HDL error at VGAController.sv(142): variable dataIncoming is written by both continuous and procedural assignments
Error(13363): Verilog HDL error at VGAController.sv(399): module "VGAController" ignored due to previous errors
KhaiY
